M
meddle
Hi , this is my first visit to the forum so apologies if i have posted this in the wrong forum. Could you please advise me re the power supply for a Belkin wireless router which recently stopped working. It was a DVE 050100 rated at 5v 1amp. It stopped powering up a couple of days ago and I have tried another power supply which is rated at 5.1v 2amps with the same polarity. The router now powers on fine with this however I was wondering if it is safe to use due to the slight difference in voltage/amps. I wasn't sure if this will do as a replacement or if i should look at getting something with exactly
The same rating. Any advice would be greatly appreciated.
