I make it around 15 amps for the star, you need to work out the line current by 230 volts, it may actually be just over, I cannot remember the exact formular, but it should be around 230 volts by 15 ohms which is 15 amps ish, the guys will confirm the actual figure later, delta will be different and probably 3 times the current, I will have to consult my book again, lol, I am learning again myself, I think you divide the 400 volts by 15 ohms, which is 25-26 amps then times that by the rootage of the design current which is around 15 amps which is 1.8 I think and it should give around 47 amps for delta, thats me done, I am knackered now, I am supposed to be retired from this lol
