Help with RCCB please | on ElectriciansForums
Discuss Help with RCCB please in the UK Electrical Forum area at ElectriciansForums.net
UK
Hello everyone, New here I’m not an electrician but I have an interest, RCCB was tripping at least 3 times a day I couldn't find a fault so I replaced and it seemed to have solved the issues, but 3 days later the RCCB on the other side has tripped, dos anyone have any ideas please? I'm so annoyed I thought I fixed it but guess not. I was thinking both units need changing at the same time? Now I have put in a new RCCB the other side is old and is more sensitive? (10 years old) I’m just guessing can someone confirm this?
I would really appreciate any help
and what qualifications have you got if you house burns down !
I’m low on funds at the moment so I want to try and fix it myself before calling an electrician I brought the RCCB used very little off eBay for tenna it’s the same brand as the one I removed, It did trip between 1 and 6 times a day but since I replaced it’s the other side tripping once every 3 days so I can’t understand what the fault could be, no recent work has been done it’s been tripping for months.
Low on funds is no excuse if there is a underlying issue that may cause harm or even death. Get a spark in woth the right equipment who will be able to rectify it properly and give you peace of mind
You are right its dangerous to be frugal with this, I will call an electrician on pay day I can live with it tripping once every 3 day for now
Thanks for the warning.
Low on funds ..... Let's hope you don't have a defrosted freezer anytime soon?
TBH without test kit and the knowledge how to use it is what you need .....
You could help yourself and make a note each time it trips and see if there is any pattern
It sounds like a neutral to earth fault somewhere in the installation. This is of course , a very vague guess and it would require someone with the correct test instruments to further investigate the problem.
If your installation was running fine, then something has changed, usually it is human intervention in these circumstances.
Reply to Help with RCCB please in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
word of caution, the federal electric breakers are old bits of kit. I have known them sometimes to refuse to turn back on if they are tripped or...
