Help with S Plan with 2 zones one controller | on ElectriciansForums
Discuss Help with S Plan with 2 zones one controller in the Central Heating Systems area at ElectriciansForums.net
D213553R
Hope you can help as have dealt a lot with heating controls have air source heat pump and install totally sub standard so I'm upgrading the wiring plus underfloor heating and thermaskirt upstairs Below is what I have
Riello NXHM 016 Monobloc heat pump
Drayton wise (DW) thermostat kit 3
2 x zone pumps for ( 1x upstairs. 1x downstairs)
3 way valve
Upstairs is thermoskirt run back to a 7 way manifold with 6 sub zones using wireless DW Thermostats connecting back to the 1st DW underfloor heating controller
Downstairs UFH 7 way manifold 5 sub zones using DW wireless thermostats connecting back to 2nd DW underfloor heating controller
My issue is I can't find a S plan wiring diagram for the 2 zones into the 1 DW controller ( as in kit 3)
Also changing electrical box to a wago 221
Have attached a couple of photos
[ElectriciansForums.net] Help with S Plan with 2 zones one controller
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do
The Wiser system is very adaptable but it is a little difficult from your post as to what you are trying to control with which stats
Reply to Help with S Plan with 2 zones one controller in the Central Heating Systems area at ElectriciansForums.net
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
As a "temporary" measure I went down a slightly different route. Nothing off the shelf appealed. In particular I wanted something with a good WAF...
Is this a plumbing question or is your underfloor heating electric? It sounds like you have a mechanical problem, like a stuck solenoid /...
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
