Help with storage heaters on eicr | on ElectriciansForums
Discuss Help with storage heaters on eicr in the UK Electrical Forum area at ElectriciansForums.net
Birmingham
Hello all, I have been asked to do a eicr on a property, as the client has asked to rectify any issues as I go along, I have come across a supply to some storage heaters running off a oldb3036 consumer unit. It is running off a 24 hour supply ie 4 terminal meter but within it has contactors. I need to change this board but how do I approach it and where do I start I ve posted some pics the contactors are within the consumer unit. Is there a consumer unit to replace it or something else I can purchase
  • [ElectriciansForums.net] Help with storage heaters on eicr
No one before I did. OP would be more than a little miffed if he got on sight, opened up his new CU, and then found the rail wouldn't take a contactor.
I see, that makes sense! I was thinking of the length of din rail and thinking why would it be half the length but I get what you mean now - not the ones where there is only the top half of the rail. Sorry, being a bit dim tonight.
Reply to Help with storage heaters on eicr in the UK Electrical Forum area at ElectriciansForums.net
Fantastic thanks Freddo that last photo confirms all your suggestions so I’ll get back over and remove the links and test. Thanks again!
