Smart Sparks
Hi all,
I am in need of some advice ahead of my ELECSA assessment onTuesday 28/08.
I decided to replace the Consumer Unit in my house and testsome Minor Works. All has been going well, replaced the CU no trouble all readyfor testing.
The trouble started when I completed the InsulationResistance test on the house ring. I was getting strange readings so checkedevery visible connection at each SO, everything was in order. I then rememberedthat we have a socket in a cupboard adjacent to our front door. It is wired inSWA and the cable runs down the side of the house and enters the housesomewhere near the CU. But when I changed the CU there was no sign of the SWAand the space between the wall and the plaster is around 10mm so I neverconsidered it may be connected direct into any of the circuits. I suspected it would be connected to one ofthe RM socket outlets for the kitchen.
However on the end of it is a Double RCD socket and when I disconnectedit the Insulation Resistance readings were fine. So somewhere in the wall it isconnected to the ring.
The ring is a 32amp conventional ring main in 2.5mm cablethe SWA appears to be 1.5mm.
Not sure what to do, do I leave it and explain to ELECSA Ifound it this weekend and will need to find the connection and remove it?.
Or will he fail me straight away if I tell him that?
In a real dilemma as if I deal with it this weekend I willnot get t repaired in time for the ELECSA visit.
Any help or advice would be really appreciated.
