Help with watts please | on ElectriciansForums
Discuss Help with watts please in the DIY Electrical Advice area at ElectriciansForums.net
J
jaelem
Hi all im trying to make a cooler for my marine tank i have 6 small fans that are interlinked with each other and they are 12volts 0.8 watts i cant find a transformer to make them work is there anything i could use that would make them work
Are the fans 12V AC or 12V DC? If they're 12V DC then a transformer alone won't work because they output DC. Can you attach a photo of the fan setup so we can see it?
ok you have 6 x 12v 0.8watt fans wired in parallel
so 6 x 0.8w = 4.8w total
ok P/V=A (watts / Votage = Current)
So 4.8w / 12v = 0.4 Amps
Therfore your looking for a 12v 400mA or higher transformer
Then you need a dc power supply at the rating of 12vdc 400mA plus or rectify a 14v ac transformer to provide 12v dc (using bridge rectifier loss 0.5v per phase 1v drop Half wave)
Soz Tazz posted same time ....
I'd be tempted to go with a power supply at double the 400mA calculated figure, maybe even 1000mA. The price difference will be small.
That would do the job fine....you can buy from maplins, cpc, rapid, rs
Reply to Help with watts please in the DIY Electrical Advice area at ElectriciansForums.net
Thanks little spark. Good point but the drivers I'm considering have a sync and communication between driver function. So (as long as it works)...
M
Hi and welcome to the forum. Thanks for posting. I'll stay out of the advice because I'm not a sparky. But welcome aboard and if you need anything...
