Help with wiring a double light dimmer switch and a single please | on ElectriciansForums
Discuss Help with wiring a double light dimmer switch and a single please in the Lighting Forum area at ElectriciansForums.net
G
Georgi_Mar
Hello,
I am not an electrician but I want to change my light switches and I have experienced a problem as I didn’t take a picture of how they were wired before. Please help.
I have one double switch in the living room which should be connected to the living room light and the bedroom light and a single switch in the bedroom just for the bedroom. So technically, the bedroom light should have a two way switch (I live in a studio flat).
I am having difficulties to wire those. Please help me if you can.
I have attached two pics of the switches and have labelled them.
If anyone can help, it would be very much appreciated.
Many thanks in advance.
George
[ElectriciansForums.net] Help with wiring a double light dimmer switch and a single please
OK. start with the switch in the living room. you have a twin/E and a 3 core/E
1.the T/E: connect to 1 switch, red to C and black to L1. (living room light)
2. the 3 core to the 2nd switch:: yellow to C , red to L1, blue to L2 ( 2 way for bedroom)
____________________________________________________
bedroom switch.
1.connect the Yellow,Red,Blue same as the 3 core in the living room 3 core.
2. put the red and black in L1 and L2, red with red and black with blue.
if the new switches are metal, then fit fly leads from the back box earth terminal to the earth terminals on the switches. sleeve with green/yellow sleeving.
Thanks a lot. I will try it tonight and let you know. It seems pretty straight forward.
And yes, the switches are metal so I will do the final step as well.
Thanks again for your help
on the living room switch, the black looks a bit dodgy. if you can't cut it back a bit, use some sleeving ( preferably red, as it's a switched live). trim ends where needed so as not to show exposed copper conductor outside of the terminals.
Good to see nice friendly advice - I was expecting to see some unpleasant comments on here.
OP, let us know how you get on. And remember as said above to MAKE SURE THE POWER IS OFF.
Reply to Help with wiring a double light dimmer switch and a single please in the Lighting Forum area at ElectriciansForums.net
Can you do a sketch of the wires and their connections but @littlespark is probably correct.
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
