help... | on ElectriciansForums
Discuss help... in the Electrical Tools and Products area at ElectriciansForums.net
K
kuksiani
im try to buy some pendant lights ...every pendant lights its made for two pin bulb...but im interesed in those who its made for screw bulbs...i try searching in internet but i cant find proper name for what i want...i think here in electrician forum can help us for find the right name for screw fiting bulbs...im not interesed in chanderlie but in single white or black bulb fiting...any internet adress for this product...
regard..
I think you mean Edison Screw type lamps.
I can honestly say I've never seen a pendant type fitting with an ES type lampholder, only ever BC.
i just had a look and none of the usual outlets have them!!! hmmmm! like wise as lenny said i never seen them, obviously i come accross them in older houses but they may have been up like 20 years?
why do you need Eddison screw ES any way! whats wrong with bayonett!! unless of course BGAS or B and Q gave you loads of free/cheap Enegry lights lol..
You can get ES pendant lampholders but only in brass
Brass Pendant Lampholder ES
You could always use
[ame=http://www.amazon.co.uk/Bayonet-Cap-Eddison-Screw-Adaptor/dp/B001PSNRYW]BC Bayonet Cap to ES Eddison Screw Adaptor: Amazon.co.uk: Electronics & Photo[/ame]
Reply to help... in the Electrical Tools and Products area at ElectriciansForums.net
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
