When wiring multiple lights from a single switch, is it possible to continue from last light with a loop to next room?
Discuss Help in the Lighting Forum area at ElectriciansForums.net
onlyif you want the next room to be operated from the same switch.When wiring multiple lights from a single switch, is it possible to continue from last light with a loop to next room?
That's quite a common way of wiring a 'simple' lighting circuit these days.Why would you want to have a loop to the next room from a single switch ?
Indeed, some are, and they get a C2 if discovered when testing.some properties are wired with the neutral in the switch -this type would not be suitable unless you wanted both lights to come on at the same time from 1 switch
Could use Quinetic switches and link the original switch out.onlyif you want the next room to be operated from the same switch.
Reply to Help in the Lighting Forum area at ElectriciansForums.net
