P
PAUL M
Went to do cu change today and noticed that the tails came out of the meter into henley block then to cu, then i noticed a 6mm swa connected into the same henley block which is backed up with a 100 amp bs 1361,so i asked him what it was feeding ,oh its for me garage so off i trot for a gander it was like a branch of kwik fit so i told him that the armoured should be downrated and put on a 32 amp mcb,but that wont be enough for me welder ,.its the same size cable as the supply coming in he says. am i missing something here surely you cant have 6mm swa on a 100 amp fuse can you? all replys welcome,cant be bothered to check the red bible it has been a long day.cheers.
