Help !!! | on ElectriciansForums
Discuss Help !!! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
J
jboy1888
Can anyone help me with this question?
"How many watts are being consumed in a circuit with 0.2 amps flowing through 100 ohms of resistance"
thats all there is to the question if there was voltage stated it would not be so hard.
P=I squaredxR=4 watts
Ohm's Law
Upvote 0
Ohm's Law
or even p=EI cos
this would also give you the true power. So i guess im giving myself the answer, i couldnt see it for looking at it. Do you guys remember this or is there something you refer to for formulas. Ohms law is straight forward enough to remember its just the more complex ones im refering to.
Upvote 0
Reply to Help !!! in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Hi tssxrr, I am also doing my assignment on the same topics. would you mind sharing the documents which you have done so I will have rough idea...
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
Electrical Courses
