shagg
Hi Guys
I've been asked by an engineer to wire a machine he's working on. and this isn't normally my area, but i don't really want to pass the job up.
The machine is a test rig with a slider arm driven by a rotation of a 3 phase motor (.18kw). Now the slider has to slide a 1000 time then stop.
the motor will requirer an emergancy stop as normal.
So my question to you guys in the know is how you would go about wiring it and the components needed
