help | on ElectriciansForums
Discuss help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
mick b
bolton
did a tes on rcd to get the tripping times, put metrel meter on auto and it tripped the rcd but no times came up on the meter. polarity is correct and Ze is good . all terminations are good . Is it a faulty rcd even though it trips.?
did the same test at home and the meter was set to the same parameters and it worked fine. is the rcd working at very low current or am i missing something
Do the test again and explain step by step what you did and how the instrument was set, function, range etc.
and report back.
In most cases its unlikely to be a faulty RCD or instrument which leaves the other variable in the trio of unknowns
OP, your turn .....
Reply to help in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I don’t see an rcd here. Is it elsewhere, supplying this board? It looks like it’s in a garage… is there excessive moisture getting into...
Assumption is the mother of all major foul-ups! Start with the basics, like IR testing, RCD testing on its own, and checking the leakage as...
