G
Guest77
I just changed a DB, and when the upstairs light switch is pressed at the bottom of the stairs the RCD trips out, I have no idea why? have you guys got any ideas and if so how do I get over the problem.
LOL, okay when the upstairs landing light is switched on from the 2 gang switch at the bottom of the stairs
And the short way of saying that is?I'm guessing the upstairs and downstairs lights are now on separate rcds. Is it an incorrectly wired downstairs switch which is feeding the upstairs light from the downstairs supply and rcd but the neutral path is through the upstairs rcd?
All I can suggest to the op reads the following to help him with his training .....
