Hep with demand and diversity | on ElectriciansForums
Discuss Hep with demand and diversity in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
M
Markymark981
[COLOR=rgba(0, 0, 0, 0.701961)]Hi wonder if u could help me [/COLOR][COLOR=rgba(0, 0, 0, 0.701961)]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Just rewiring a 3 storey house that's going to be student lets, communal kitchen lounge bathrooms etc[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]I have worked out the following diversity and demand [/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Emergency lights 6a x 0.66 = 2.64a[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Smoke alarm 6a x0.66 = 2.64a[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]4 light circuits 4 x 6a x 0.66 = 10.56a[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]4 ring mains 32a + (3 x 32 x40% = 38.4a) = 70.4a[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]That all totals 86.24a [/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Dilemma I have is adding electric cookers and electric radiators [/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Customer ideally wants 2 stand alone electric cookers but I've worked out each cooker assuming 40a would equal 29.16a if he had 2 it would be 58.32a [/COLOR]
[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Then he wants 500w convector heaters either 7 or 15 of them spilt over 3 floors in total 15 would bring 7kw and need to be on a 32a fuse and if he went for 7 it would be 3.5kw and need a 16a fuse, apply diversity and that would add 21a or 13a[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Questions I have are[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]1. if he had the electric rads could I put 3 radial circuits into one 32a fuse [/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]2. As it stands without cookers or rads it's would be[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]86.24a[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]115a with one cooker[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]144a with 2 cookers[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]157a with 2 cookers and 7 rads[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]165a with 2 cookers and 15 rads[/COLOR]
[/COLOR]
[COLOR=rgba(0, 0, 0, 0.701961)]Which would be acceptable, my old old lecturer stated if it exceeds 100a it'll just blow main fuse so don't worry but I am as already going to have to get him to upgrade it he 80a main fuse to a 100a
oh and I have just found someone using the add up all the mcb values and times by .40 anyone else used this?
[/COLOR]
Hi Mark.
Without trying to decipher the message too much I would say:
Work out the max demand for the lights/smokes and other items with a known power output based on there total wattage rather than the MCB.. and then apply diversity.
Also, I dont think it is a good idea to just think that it will have a 100A fuse so if it takes more than that it will 'just blow'. A 100A fuse will never blow with 100A flowing through it, will take at least 30minutes to blow with 200A flowing through it and perhaps days/weeks/months (or never) with 115A - 165A flowing through it. So it would be a poor design and dangerous especially if the tails are 16mm .. are they?
Saying that.. I doubt your actual demand will be anywhere near that high in reality.
As for the x0.4, I do see that banded around alot. I think it is from a particular DNO but cant be sure. I expect it is accurate 95% of the time, but I have always felt like it's cheating a bit because you just want to make the figures fit rather than give them proper consideration! I still used it once though!
Reply to Hep with demand and diversity in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sounds like one of those jobs to swerve and let it be someone else's problem
even allowing for diversity this sounds a bit tight for a 100 amp supply, can you tell us what the existing circuits actually have connected to...
