Hi I have installed a new ceiling lights switch but it doesn't work | on ElectriciansForums
Discuss Hi I have installed a new ceiling lights switch but it doesn't work in the DIY Electrical Advice area at ElectriciansForums.net
Keith B
Carshalton Surrey
DIY ENTHUSIAST NEW FORUM MEMBER.
I took a photograph of the old wiring set up( which was working) and used it as a guide for wiring the new one.
The lights themselves are housed in the loft above and I was wondering if a fuse has blown in the plug or that there is a reboot button somewhere.
Could we possibly get a photo of the old wiring and the new switch?
Light fittings don’t normally come with plugs and fuses… so I would imagine this is simply a wiring error at the switch and nothing too serious.
Is it just a regular switch, dimmer or electronic smart switch?
Hi apologies for the delay in responding. The switch is just a ordinary pull switch
  • [ElectriciansForums.net] Hi I have installed a new ceiling lights switch but it doesn't work
Is there any other wires above the switch?
Is it 2 separate cables? One red and bare earth, and the other black and bare earth?
Or is it a twin and earth, but then where does other bare earth come from?
Looking at “light pull 4” it doesn’t appear that the black is fully in the terminal, unless it’s really long.
Power off, give the black a pull and see if it’s loose.
Hi again, there are 6 lights in the bathroom ceiling with access to the electrics in the loft
Are you changing the switch because it was faulty, or just for aesthetics?
Was this a case of simply changing a switch like for like ?
As said, it's a little strange to have the extra cpc.
There's an issue or two that needs addressing here, but a possibility for the lights not working is that it's a 2W switch, and the connections have been made to the two strapper terminals. Easily done if the original switch was marked, L1, L2, and L3, and the new is marked C, L1 and L2.
Reactions: DPG
Looks like the lights are off and nobody's at home :)
Hi Yes it has two earths, I will do as suggested thanks
Reply to Hi I have installed a new ceiling lights switch but it doesn't work in the DIY Electrical Advice area at ElectriciansForums.net
Well that mean to either send it off to megger or I would us calabration Manchester ask them.
Yes one wire nut will grab a wire but I will suggest an orange one because the wire is 14 gage wire for lighting.
