J
jonboy32_nz
[FONT=helvetica, arial, sans-serif] i have a problem ..on my motor cycle headlight im running a 3 way switch ..left (low beam) middle(power) and right ( high beam ) switch works fine switches between low and high ...the problem on having is ive run a blue led indicater light straight off the high beam wire and when i switch to low beam the led still comes on but not as bright ...i know i need a diode or resister or somthing to drop the voltage so any slight voltage getting to the led wont let it light up but the question is what exactly do i need[/FONT]
