Hi,new to the forum after advise and willing to learn Thanks | on ElectriciansForums
Discuss Hi,new to the forum after advise and willing to learn Thanks in the The Welcome Forum area at ElectriciansForums.net
E
Eazy 26
Hi
I'm after some advise on electric underfloor heating?
I've recently taken over a job were the previous electrician (kitchen fitter) has left the job half done and left them with an unfinished job mainly all 2nd fix
He's laid 2x 20m matts to cover a 40sqm room and he's put 1 prob and Both tails from each matt to a 35mm box with a supply from a dedicated circuit which was isolated by a 20amp double pole switch the two matts will be controlled by one thermostat rated at 16amps. from what I have found out through the customer is that the Matt rating was 200wpm so by my calculation
40x200 = 8kw /230 = 34.78amps.
So 34.78 amps into 16amp thermostat?
What's my solutions?
I've had a quick read up about contactors ,relays and snubs to be honest I have never used any of these so not sure on were and how to wire them into the circuit.
This install is completely plastered/decorated so re-wiring or major changes to the circuit can't be done unless local to existing wiring
After any helpful advise
Cheers
what lunatic specified electric underfloor heating for a room that size. madness. something close to ÂŁ100 / week in leccy.
They were sold it as part of the kitchen install I had a rough measure up and you could of got away with 0ne 20m Matt after you minus all the fixtures and fittings the Matt goes under all the units
Use the stat to switch a contactor, this may have been the original intention.
What type of contactor would be needed?
And can you get small contactors that would fit inside a 35mm box?
In my mind I would have a feed from the stat to a contactor and the cold tails to the contactor aswell?
Reply to Hi,new to the forum after advise and willing to learn Thanks in the The Welcome Forum area at ElectriciansForums.net
Nothing wrong with it. Which manufacturers have you got this information from? What do you mean by trip speed? Fuses and MCBs can operate in the...
davesparks
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
