Hi. Optima wired alarm issue | on ElectriciansForums
Discuss Hi. Optima wired alarm issue in the DIY Electrical Advice area at ElectriciansForums.net
GaryFear
Stafford
Hi. I have a wired Optima alarm. Due to wiring access issues, I need to add a wireless door sensor. Sometime back, I recall seeing a product that was a receiver powered from the 12v supply in the alarm panel and a wireless door sensor with transmitter. Does anyone know of anything suitable. Thanks in advance.
Reply to Hi. Optima wired alarm issue in the DIY Electrical Advice area at ElectriciansForums.net
The previous bell box worked fine. I think it was just lacking the added security of anti tamper. Can this one be wired the same?
Hello That sounds like a bit of a nightmare. Did you manage to get sorted in the end?
Thanks Bennie. Yeah I have Oslo microwave sensor 2D type fittings which I was hoping to use. So permanent supply to all this would suffice? Thanks
Hi all, I currently have a Pyronix Enforcer V10 Wireless alarm system. I have some shock/contacts on windows, doors, PIRs, and an external siren...
These keypads are obsolete and replacements are hard to find, I've replaced loads now with failing displays. Sounds like something isn't...
