dingledong
i,ve had my house rewired and watched the electricians carry out the work. they have left behind a plug in tester with the 3 lights a flathead and phillips screwdriver and i'm going to buy a light up screwdriver . also i come on here can i now call myself an electrician
:dozey:
You will also need some trousers with flappy pockets and suggest you get a toolbox so that its not obvious you only have three tools. An old clip board with some scrap paper on and if you can get one, an old polaroid camera to put around you neck to look like a tester, just attach some wires to the lens, will look the part - Good luck, dont forget you can always come on here for all the answers you will ever need :-)
i,ve had my house rewired and watched the electricians carry out the work. They have left behind a plug in tester with the 3 lights a flathead and phillips screwdriver and i'm going to buy a light up screwdriver . Also i come on here can i now call myself an electrician
:dozey:
yeh you can do your first job and leave your tool s behind for someone else
i have flappy pocket trousers?? they help keep my hands warm.
hi
dingledong,
Welchyboy,
