B
Brad_88
240V into gearbox and 120V output on lamps that works. The lamps that are not working are 240V input and 240V output. The gearbox is REBUS R35GB.
Discuss HID Gearbox Problem in the UK Electrical Forum area at ElectriciansForums.net
At a guess I think the OP means Robus control for HID lamps used for display lighting (Also used for growing things :sifone:sometimes).
HI Brad can you confirm if you mean Robus?
Are these 35w HID display lighting for commercial use like shops etc.
just swap the complete gear box saves fafing around
they cost about £35.00
Reply to HID Gearbox Problem in the UK Electrical Forum area at ElectriciansForums.net
