High current CEE form plugs/sockets. | on ElectriciansForums
Discuss High current CEE form plugs/sockets. in the UK Electrical Forum area at ElectriciansForums.net
DNS1
Hi chaps,
Can someone enlighten me as to what the fourth pin is for in a single phase CEE-form plug? I've noticed that some 63A+ plugs have them and some don't...
Don't know why I've never wondered about this before... Was just faffing with some the other day and it got the grey matter working!
They're made in 2P + E, 3P+ E & 3P-N-E configurations, confusingly rated across all three voltages (colours).
Therefore, if you've got a blue 63A which has four pins it means it's a 3P + E.
It's not single phase if it has 4 pins it's 3 phase and earth.
Exactly, but you are supposing a 400V 3ph!! If you take Lewden, for example, their range goes 110 -230-400- 500V (yellow, blue, red black) but in all pin configurations. So yes, 4 pins = Delta plus Earth, but that could be at any of these voltages. Not everyone lives in Europe!!
The spare pin on a 63a single phase plug is a reference pin doesn't actually get used for the supply. Not sure how exactly it works but I believe it is to confirm that there is an earth path before the supply is activated
Blue plugs are single phase
Red plugs are 3 phase
Yellow plugs 110v low voltage
WRONG!!
Colour denotes voltage, it's the pin configuration that denotes phasing. And it's not a reference/pilot, it's the earth pin in a 3P+E config - the colour doesn't matter.
This page from the Lewden book explains it all far better than words can!
[ElectriciansForums.net] High current CEE form plugs/sockets.
Then of course there's also 7 pin.......
Right it is a pilot pin in a 63a plug blue single phase ceeform it's shorter than the other pins and it's used to stop the connection being made on load
I haven't come across many systems that have the pilot pin wired so I don't have first hand experience of them.
There is a diagram at the bottom of the page that shows this configuration
http://www.farnell.com/datasheets/1504039.pdf
Reply to High current CEE form plugs/sockets. in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
