F
FIT-PV
Installed a 3.92kW System today. Using a 4000-TL SMA Inverter. The inverter gave a grid voltage error. After checking the input voltage it was at 255 which is definatley too high for the SMA Inverter. The house is only a few doors away from a sub station which may be causing this.
What are the best solutions for this
1. Call DNO and get them to reduce voltage... likelihood is it will take some time
2. Install a voltage optimizer?
3. Change setting in Inverter using the Grid guard code to up the limit? I presume I would need DNO permission to do this?
4. Other?
4. Other?
