surreysparks
Hi all.
quick question, on a rfc wires in 2.5 single or tne, can you use high integrity sockets and terminate each cpc into a different terminal, and same at the db, or do you have to pull a 4mm radial cpc
in aswell.
i learnt that you could just split the cpc at college years ago, but reading up it apparently needs to be 4mm?
also what would you code a computer circuit with no high integrity earthing on a eicr?
in aswell.
