High/Low Speed 3 Phase Fan Contror??? | on ElectriciansForums
Discuss High/Low Speed 3 Phase Fan Contror??? in the Commercial Electrical Advice area at ElectriciansForums.net
G
gareth020
Hi
I've been asked to move 2 x 3 phase fan control boxes with high and low speed start buttons, stop buttons and LED indicator lamps. They control 2 roof fans. Inside one of the boxes the coil has gone on one of the contactors and needs replacing, but to be honest both boxes are quite old now and the cabelling has not been installed to a good standard. So i was going to suggest replacing the whole unit, but don't want to attempt this until i understand the theory and how it all works. Could anyone suggest where i could get a wiring diagram to study or point me in the right direction on how the control circuit works??? I have searched the forum etc but not found anything yet.
Much appreciated guys
As Silva has said have a look through the e-book. There's only 700+ pages
The starters are easy enough, but mak sure you mark the cables to the motors. They don't like going from fast forward to slow reverse.
What would you suggest Paul?
This sounds old kit and the owner will most likely baulk at the price for two new starters with the correct control voltage.
In my minds eye I can see the outcome. The starters will be moved still with one knackered contactor.
But you never know, miracles do happen and the owner will pay out.
Reply to High/Low Speed 3 Phase Fan Contror??? in the Commercial Electrical Advice area at ElectriciansForums.net
You are quite welcome my friend and good luck. I wasn’t trying to insult your intelligence and sorry if it seemed that way. Have a great day
Here are the other drawings
    • Optimistic
    • Funny
