High r1 | on ElectriciansForums
  • Thread starter piz
  • Start date
  • Replies 4
  • Views 1K
Discuss High r1 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P
piz
Hello All
I have been testins a ring main and I have a reading or r1 15.57 Ohms
r2 0.90 and rn 0.50 why is the phase so high I have been to most sockets and tightened the phase any other ideas please:(
Check you havent tightened on the insulation as oppose to tha core, done it myself b4 now m8 and spent a gud hour scratchin me head!!
Definately sounds like a high resistance joint on r1 there somewhere......could be a hidden JB somewhere, double check all sockets on that ring making sure you havn't clamped the insulation in the terminal, re-test and go from there.
Thanks guys 8.00am tomorrow another go I know it sounds stupid but will it read different if the loads are still connected (Higher)
Reply to High r1 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You would be best checking all connections as it is possible it is having a cumulative effect.
For what OCD? There may be other means of over current protection that allow a Zs of0.45 (HRC Fuse?)
