High ring test results at socket outlets | on ElectriciansForums
Discuss High ring test results at socket outlets in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
maudy
London
Hi, I was wondering if you guys can help with some errant test results.
I'm testing a ring and i get
L-L = 0.41
N-N = 0.40
E-E = 0.63
Great
Figure 8 L-E = 1.0 ohms.
Still good
Figure 8 at each socket varies from 0.8 ohms to 1.1 ohms (I was expecting much lower)>
Oddly Zs = 0.23 (which is what I was expecting for both this and my R1-R2 [at socket] tests.
Any ideas?? System is TNS / Ze of 0.09
Maudy
your fig.8 R1+R2 should approximate (r1+r2)/4 so your 1.0 ohms looks high. are you sure you have nulled leads for the R1+R2 readings?
make sure you null leads are you on right legs of ring your fig 8 should be aprox 0.26 given the values you have given the reason the readings might be different at various points is possible spurs
check at terminals of outlets as i installed a load of mk sockets and readings at fron varied wildly
N terminals were hard work to screw down plastic seemed to be restricting it
ended up removing them all and replacing with BG
also as you say your reading increased was this to the mid point of the ring as you could have incorrectly identified the legs and not carried out cross connection correctly
your R1 +RN should be more like 0.2 and your R1 +R2 should be around 0.26ohms or within 0.05 ohms of each other so 1.0ohms to high
How are you measuring your figure of eight? It sounds asthough you are disconnecting the cables from the sockets and measuring 2 end to ends as the results are your L-l and E-E added together
Mhahaha
Yea - its wired in T&E so I wouldn't make that mistake.
It not that the socket readings start off low and get higher - they're all too high. Or as I suspect the figure 8 end to end (measured at the board) is too low. WHich makes me think Murdoch is right.
Reply to High ring test results at socket outlets in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
5K
