R
Ross Trician
Morning all,
began doing second fix and testing etc on a job, I changed th CU and on conection of tails and testing for voltages in the cu, (just to prove feeds thru rcd's etc prior to conecting all circuits) I found the incoming voltage was 314V.
Why is it so high, do I need to contact the supplier?
It did answer a question raised by the customer tho when discussing types of lighting, she said they had spot lights before and they were for ever blowing bulbs, presumably due to the excessive voltage.
Also if the voltage is supposed to 230V +/- 10% shouldnt the supplier be monitoring this?
thanks ross.
thanks ross.
