High Ze coding on new EICR | on ElectriciansForums
Discuss High Ze coding on new EICR in the UK Electrical Forum area at ElectriciansForums.net
Still trying to get to grips with new EICR coding - got 400 ohms on earth rod all protected by 30mA rcd. What would you code this as under the new EICR?
Code 3......it complies with the BGB in all aspects other than the recommended max of 200 ohms.....and assuming the RCD(s) operate within spec disconnection times are met.
No doubt there will be cries of anguish from some.....but the sole purpose of an EICR is to highlight deviations from BS7671,it is not permitted to bring personal preferences into coding. A code3 is nevertherless recommending improvement,and this could be explained more fully in the report summary.
Personally, I'd also code it 3, with a note in the comments box though looking at GN3 (new version) and the BGB I can't see any reference to a 'recommended max' of 200 ohms, only that values over 200 ohms may not be stable​
I agree with the above.
In a TT with all circuits protected by 30mA RCD(s) then the impedance of the earth path could be as low as 1666ohms.
HOWEVER
400ohms is very low. Maybe its not in earth but sitting in a pit filled with hard core?
I would make it a Code 2 and recommend you bang in a new earth rod.
Only while the RCD is working correctly!! lol!!
Agree with wirepuller in this instance, as this is conducting an official EICR to the current wiring regulations/BS7671.
...Not that i particularly agree with this section of them!! lol!!
I take your point...I've always considered this to be a roundabout way of recommending a max of 200ohms.....but you are correct,it's depends on your interpretation.
Reply to High Ze coding on new EICR in the UK Electrical Forum area at ElectriciansForums.net
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
