I have recently re-wired a property with T-N-S earthing to find out that the Ze was 13.41ohm. I checked all the supply have to the spilt concentric incomer that looked pretty new. All connection were ok so i rang norweb. The question is does the DNO have to supply an earth to the property? An electrician i know said that the can just make to sort it yourself with an earth spike.
Cheers Paul
P'S before i left i put a 30ma RCD between the tails and the consumer unit
Cheers Paul
