High Ze,s | on ElectriciansForums
  • Thread starter Scott F
  • Start date
  • Replies 9
  • Views 2K
Discuss High Ze,s in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Scott F
When on say a TNCS property you get 0.7 say for Ze
What do you tend to do note it on the cert and let the customer deal with it ? (Thing is I feel they probably won,t deal with it )
Or take it upon yourself and wait a week on the off chance they MIGHT turn up.
Any views appreciated.
I think you will find on a TNS and TNCS system its down to the DNO to sort that out not you or the customer. Oooops you said Ze might help if I read the post first
Chris
Ignore my ooops it is very obvious I am having a really bad hair day
Hi mate.
Personally I would contact the DNO myself and see what the score is. It's their responsibility to provide you with a Ze of less than 0.35 on a TN-C-S.
Thanks for the quick responses
I gave the DNO a ring to enquire what earthing arrangement it was .
Looks like a converted TT - TNCS off the pole into heatshrink then into concentric
Neutral the same only doubled up with a 16mm earth wire .
looks like a DIY
High Ze could be loose connection or could just be its out the way
By the sea out the way
And this is the point its a holiday home I did a PIR for I get the work via a letting agent so would have to arrange when no ones there and get the keys and even then DNO might not turn up
I rang them the other day (6mm main earth sweated on to lead sheath was there all day a monday and they ring me Thursday to tell me there outside)
I do not want to spend a day or so wasting my time BUT MY responsibility usually gets in the way of smooth rides .
IF YOU yes YOU had to go back and arrange for the DNO to turn up would you charge for it obviously its extra cost for the client, but your spending your day waiting .All replies greatly received Scott
Come on boys its not a hard one !
I am assuming there is more than 1 of you who are self employed and have encountered this situation ?
Depends how generous you are feeling but yes i would do the same and charge customer for the time.
You gots to charge for your time mate, you could be somewhere else earning a crust so if you have to be there for access then bill them accordingly.
Can the letting agent not wait around all day for them.At the end of the day the incoming supply is not your problem.All the time your'e waiting outside let them know it is costing them ÂŁ20 an hour :D
Reply to High Ze,s in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
