F
foghorn
what causes high zs readings on a ring socket circuit and when testing end to end l=0.60 n=0.68 e=over 200 help what could this be
Discuss high zs readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
thanks for the reply and comments however we all need a liitle advice now and again my thinking was also loose cpc but having only replaced consumer unit and not doing a full periodic how far do u go and surley loose cpc would not such a high r1+r2 could it be that the ring is cross connected with the other ring as other ring was not giving continuity on e-e but did on r1+r2
Reply to high zs readings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
