M
markc17
Hi all, some advise please...
I have a building full of type 4 3871 FE breakers, that have recently undergone a PIR. Many of the ring circuits have come back as having high Zs readings and have thus failed, with each only failing by like 0.04 of an ohm. There are no earths in the circuits, with the conduit and trunking system being used. Without going into reasons why, it is unlikely i am going to be granted the time or resources to pull new earth wires down to each of the affected circuits. Was just wondering my options... I have managed to procure some 30ma Federal Electric RCBO's off Ebay, and was wondering if by fitting these it would mean my readings would comply? Ill be honest, im a bit confused by the 1,667 ohm allowance on a 30ms rcd. Any clarification would be greatly recieved.
Just so you know, i cannot gain access to alot of the conduit system, so am unable to tighten much, i could possibly increase some of the bonding?
Thanks, Mark
Thanks, Mark
