Hissing sound from under sink plumbing advice | on ElectriciansForums
  • Thread starter Seo195
  • Start date
  • Replies 0
  • Views 101
Discuss Hissing sound from under sink plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Hissing sound from under sink Heya,
So there's a hissing sound coming from underneath my sink that feeds my washing machine and dishwasher. I initially thought it was a weeping connection or a pinhole in an old pipe, so I turned the water off. The hissing was still there but as soon as I drained what was left in my cold tap it stopped. My brother who is not a plumber but has been in the building profession for many years also took a look and neither of us could find any leak or any wet spots of any kind. I also checked the back of the washing machine and dishwasher, everything is working as it should and I have since turned my water back on. The hissing is still there however, my brother mentioned something about the water company increasing the pressure during the summer? But I don't know if this is true. I am on a mains supply. He also said it just sounds like water in the pipe, but I'm still not too pleased. Don't really want to bother a plumber when there is no actual visable wet patches though.
Any idea what it could be that is causing the hissing sound, maybe air in the pipe? It's not bothering me but I just don't want a massive leak if pressure is building.
Any help is much appreciated!
Hissing sound from under sink to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Hissing sound from under sink plumbing advice in the Plumbers Forums area at ElectriciansForums.net
J
How do I fit pipes under kitchen sink? I took Apart pipes under 1 and 1/2 sink, and now I can't put it back together. Can anyone help please How...
Julie c
J
J
Purpose of vent under sink? There are bad smells that come from my sink drain when I run water. On inspecting (undoing) the U-bend trap, there is...
Jimmy8127
J
R
total blockage in kitchen sink what will cut through whatever is blocking my kitchen sink? I've put sulfuric acid, and then later i put a whole...
razorback
R
This is an RSS feed of thread: Water in both sinks are going down slow Content of the thread: Hi All, I just had a question about something I...
E
Replace a water tap Hello, I have to replace the kitchen's water tap. I am attaching images (*.img) of the under sink existing pipe connections...
Erico19
E
