Hive my old thermostat | on ElectriciansForums
Discuss Hive my old thermostat in the Central Heating Systems area at ElectriciansForums.net
notts
I have my new hive system up and running but want to take off the old thermostat which is set at 30 degrees as the hive over runs it. I want to put the wireless hive in the same place as the old thermostat but don't know which wires to join and which ones to just leave or cover. I know its not good practice to do this but I want to leave them there in case I leave so I can put the old thermostat back in situ. Ive took a pic of the inside of the thermostat.
[ElectriciansForums.net] Hive my old thermostat
Put 1 & 3 into same wago/choc block. Put 4 into its own wago/choc block.
Should have run a stanley knife around that stat before you pulled it and half the paint off with it though[/QUOT
Thanks for that yes I know I messed up lol but hopefully I can find some extra paint before the mrs notices lol
Reply to Hive my old thermostat in the Central Heating Systems area at ElectriciansForums.net
That's just a standard timer switch. The 2 red wires to the timer are the switch contacts, the 2 blue wires are power to the clock. The 'orange'...
As a "temporary" measure I went down a slightly different route. Nothing off the shelf appealed. In particular I wanted something with a good WAF...
