hmmmmmmmmmm | on ElectriciansForums
Discuss hmmmmmmmmmm in the UK Electrical Forum area at ElectriciansForums.net
i=p/u
Northern Ireland
in your experience's guys what is an average rating of 3phase coffee machine??? i couldnt find the rating on it but is coming off 32A breaker
surely it cant be 32A each phase
il find out tomorrow ,marvo, could do with the manual but i know a similar one is on 32A breakers, wired in 4mm but maybe this is an oversight on the the installer
i just cant see a coffee machine pulling more than 20A on each phase..
I don't see it either. A 3 head machine would be 4-8Kw depending on the volume it's designed for and the elements, usually 3 of them, are generally 230v. I'd be surprised if it's more than 10A per phase on a 3-phase supply.
Reply to hmmmmmmmmmm in the UK Electrical Forum area at ElectriciansForums.net
Thank you... I'll get up there have proper look, this was just a 1st glance !
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
