J
Jimmyb
hello, Is there a reg that means you must use a connection point instead of the wire coming striaght out of the wall into the hob.
I have always used a connection point but where the hob is to be installed there will no access below and it has a dishwasher to one side and washer and the kitchen fitter dosent want them behide as someone might confuse them with the flex out lets and connect them to, (i did see the point diy'er) he said every other sparky they have used have always just come from the switch striaght into the hob.
I did have a bit of job with him reguarding the wiring for the point for other items as he wanted them all on sockets in the next cupboard along and didnt believe that you are not suppose to fix to the kitchen unit and now says i must have it wrong and i wont getting any more work as other sparky are more then happy to do as he requested.
many thanks
many thanks
