Hob with 475mm depth cutout | on ElectriciansForums
Discuss Hob with 475mm depth cutout in the UK Electrical Forum area at ElectriciansForums.net
Dartlec
Kent
Anyone know a decent online retailer that actually lists their hobs by recess dimensions (or even lists them at all in some cases?)
Side rant - why do a lot of appliance websites tell you all the information except the bits an installer might actually want to know, like recess dimensions or even wattage
Need to replace a part failing old Beko hob in a granite worktop so measured first and the depth is only 475 - every hob I can find (at landlords end of the market at least) states 490mm as a requirement.
Most of the big companies don't list these dimensions in a way that can be easily searched, but even going through them manually I'm struggling to find one that definitively would fit.
Closest I've found is this Indesit - which says 475 in the description but has a picture showing 490 and the manufacturer states 490 in the manual online..
I either find one that's 555 x 475, or get the landlord to have the granite cut out.
It's only failing on one ring, so I could replace that, but I prefer to put ceramic ones in because they are so much easier for tenants to keep clean....
Get him to supply it and have the granite cut and you just wire it in, I just love the bloody hassle trying to source the item and fit it in.
I need to find better landlords ? Mind you, my line in the sand on this job was that I am NOT removing the two storage heaters in a 4th floor flat...
Get your router out and a buy a Corian plunge bit and become a kitchen fitter.
Look on the Trend web site for hob/sink templates/jigs.
Multitool and a cheap worktop and I'm fine - just not sure this is the ideal job to start practising my granite skills....
Reply to Hob with 475mm depth cutout in the UK Electrical Forum area at ElectriciansForums.net
Complete guess, but it's probably cheaper to let a separate meter read a CT clamp and send the data to the charger's microcontroller using rs485...
