Hole saw advice | on ElectriciansForums
Discuss Hole saw advice in the Electrical Tools and Products area at ElectriciansForums.net
Broxbourne
Hi, when using a hole saw for downlights etc., I use the DADE. The problem I have is that the arbour is very short so my drill only just bites down. What does everyone else use with the DADE? I’ve seen videos where the arbour seems quite long and plenty of length for the drill but wondered which ones they are? Thanks
Does that give you a longer arbour?
Well I find the drill bit reaches the surface to be cut easily, then as the hole saw cuts into it, the DADE flexes as it hits the surface.
PS: for those wondering about the DADE, for a while I used an old tupperware with a hole in the middle, being too mean to buy a DADE, but once I'd tried one, so much easier, you can keep both hands on the drill.
take the pilot bit out and fit a longer one. you can get longer (6mm?) HSS bits
If you cut an old space-hopper in half,and then make a hole in the bottom,just big enough for your wrist.....you don't need any of the above :)
so you punch the hole in the ceiling? no need for drill and holesaw? :( :(
Bosch progressor, got a kit on offer in Screwfix last August, wish I'd been using them sooner, far better than any other brand, teeth stay sharp for much longer, even drilling through H Irons.
You can buy a pack of adapters to make any holesaw a progressor, but id not be moving away from the bosch, pay a bit extra, last 2 or 3x as long
My dad used to have a device similar to the DADDDDE
it was moulded hard plastic similar shape (slightly larger) to a DADE but had a spout on the side which you could attach a Hoover to the spout to suck up the dust particles.
only issue was most Hoover hoses were too short so you had to hold the Hoover in one hand and the drill on the other while up the steps
Reply to Hole saw advice in the Electrical Tools and Products area at ElectriciansForums.net
I think I know exactly the stuff you mean - called insulating board (I think) and it's like the stuff you get on pin boards for thumb tacks. I...
