Hollywood mirror fault | on ElectriciansForums
Discuss Hollywood mirror fault in the UK Electrical Forum area at ElectriciansForums.net
Kincha123
Southampton
Hi there. My daughter has a "hollywood mirror". The lightbulbs around the outside have all started flickering/flashing when turned on. Could this be an electrical problem? Please help!
Welcome to the forum mate.
Could do with a bit more info on the set-up.
What lightbulbs are used? LED's?
How are they wired up?
As above, is there a driver fitted?
again, as above, have you checked for loose connections? Of course with the power off.
Any pics of the wiring?
Reply to Hollywood mirror fault in the UK Electrical Forum area at ElectriciansForums.net
😄 It wasn't the worst I seen over the weekend. Took the kids to Cumbria zoo whilst over there, and the toilets by the giraffes just had twin...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
