Home Automation..... | on ElectriciansForums
Discuss Home Automation..... in the UK Electrical Forum area at ElectriciansForums.net
J
JVMElectrical
Just been looking on Maplins and see they are doing a system called Lightwave RF anyone used it or had any experience with it? It looks simple with a main box plugging into the router and swapping out different accessories that you want to control.
LightwaveRF WiFi Link | Maplin
Anyone know of any other system like this thats simple to use and cost effective? Just looking at it to play around at home as in the next 12 months I'm looking at building a new house so things could get interesting :)
Thanks Jamie
It works, but it is budget stuff. You get what you pay for at the end of the day. It isn't as fancy as they like to make out.
If you want to do a couple of funky tricks with your lights and heating, it works, but don't buy into it thinking that you will be able to fully automate your home, because you won't.
Reply to Home Automation..... in the UK Electrical Forum area at ElectriciansForums.net
So I'm tinkering with the API at the moment, writing a little Javascript server process to do some data processing... the documentation is a...
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
