Home automaton/control monitoring | on ElectriciansForums
Discuss Home automaton/control monitoring in the UK Electrical Forum area at ElectriciansForums.net
J
JAGinfo
I wish to control/monitor status of many devices at home.
I have wifi devices that can be turned off and on. But I cannot tell if my garage door is closed or open.
I have a wifi thermostat for my home but cannot control my pool heater.
What interface do I need to bring my smart home together?
Thanks for your helpful replies.
Jeff
It all depends on how much control/flexibility you want. There are many controls manufacturers but only a few are really economical in a domestic environment.
If you can give a bit of a list of the items you would like to control/monitor I could give you some better advice and possibly help you out with it.
I work with building controls for a living so should be able to help.
Reply to Home automaton/control monitoring in the UK Electrical Forum area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
