I am looking to order an electric car and noticed on the suppliers of charging pods websites they generally ask if its a complex or simple install. It would be 7KW charger ideally I would like installed. I'm just trying to work out if I would need lots of additional work doing or not so hoping someone can help before I take the plunge.
I have attached photo of the main fusebox in my property and the small RCCB box in garage.. The thick black cable from bottom right of main fuse box/panel runs through to garage RCCB panel. There are what look like two feeds of the garage RCCB panel to garage lighting + Central Heating and I assume some other sockets in house (as one grey cable feeds back into house).
Could anyone tell me what extra work would be required to a charging point attached to garage - I assume worst case is a new cable pulled though from main fusebox (which it would be nice to avoid as this would be underfloor across the house). I'm hoping they can do something with the existing supply to the garage.
