Baker1988
Hi I have go a bit of home work but im unsure about one of the questions it says
You have been tasked by your supervisor to install a new A3 circuit in the store room for a general workers to use, you go into the distrobution room and see it is a 3phase board with bs 3036 fuses, are you able to comple the task asked by the supervisor, if so explain why?
I think it will be ok to install a A3 circuit on 3036 fuses aslong as the sockets are rcd protected by a rcd either inline or incorporated into the socket.
Would you say that was ok
yes, but if cables are buried inn wall/s < 50mm deep. 522.6.101 applies also.
Baker1988
Kingston Upon Hull
United Kingdom
homework 3036
Electrical Course Trainees Only
Baker1988,
MDJ,
