Honeywell evohome | on ElectriciansForums
Discuss Honeywell evohome in the UK Electrical Forum area at ElectriciansForums.net
C
Chris Milne
Have any of you guys ever wired one of these systems? More importantly has anyone set one up? The sales man came to see me and the plumber about it but he didn't inspire me with confidence! Firstly he said that one receiver would control 32 zones but after reading the manual I understand it only controls 8?? Also he said that the controller can only control 1 receiver so the client has bought two controllers for 2 receivers, but again I understand one controller can control up to 8 receivers? Any advise would be appreciated.
From what ive seen and read, each controller can control up to 8 receives. You can link up to 4 controllers giving you a total of 32 receivers on a system.
its a wireless system between controller and receivers. any only very limited wiring between directional valves and possibly boiler. (which will be simple enough)
Also knowing Honeywell products, it will be fairly straightforward to set up and commission.
evohome - Honeywell UK Heating Controls
Reply to Honeywell evohome in the UK Electrical Forum area at ElectriciansForums.net
You need a wi fi switch that is compatible with your switchbot thermostats. Remove the SCR, use the neutral and live to power the wifi switch, and...
Thank you for the update. It's always nice to know that a problem has been solved, or at least understood! Unfortunately not all those seeking...
