- Joined
- Apr 21, 2012
- Messages
- 85
- Reaction score
- 9
Called out because the Honeywell digital timer(does ch & hot water)
blew up!! They've recently had a new combo boiler fitted.. Which is temporarily connected to
a supply but the timer etc has been left disconnected!!
Plumber thought there may be a faulty/damaged cable, But no breakers/RCD tripping.and the new boiler operating fine now
it's fed straight off the ring.
i guess by switching either the ch or the water on constant I should get 230v on the relevant terminals on the honeywell
connecting block but now it's knackered I don't. Thing is if I fit a new one I could
have the same problem. Any ideas? Apart from send the plumber back after dissing all the wiring
