E
egginyourface
Can some one advise me on a problem im having with this heating system.
Ive wired the programmer exactly how the instrustions said. it exactly like this diagram
S-Plan
the thing i dont understand is the boiler has a seperate output which is L-N-E to the pump
Then L-N-E & R(switched live from no 10 in joint box ) is this right? Ive also fed pump from no 10 from joint box so im not using the output from boiler.
Also I didnt realise boiler needed perm L so ive pulled in supply.
when ever i call for heating boiler comes on for a short while then turns off after couple of min
Hot water doesnt work at all although terminal 10 goes live when hot water is called for.
plumber is just as confused as me and he thinks he may have mixed flow and return
can this cause this
S-Plan
can this cause this
