Honeywell st699 to st9400c wiring | on ElectriciansForums
Discuss Honeywell st699 to st9400c wiring in the UK Electrical Forum area at ElectriciansForums.net
UK
Hello I have a question switching the above central programmers. I seem have a few more wires than other examples I’ve seen online.
For instance I have 3 wires in terminal 1 (brown and 2 red: one is a bridge to terminal 5 which I believe would be discarded); also have 3 wires into terminal 2 ( 2 blue and 1 black). This setup seems to have more wires than other examples. Can anybody guide me on how to switch over to the st9400c?
Thanks in advance.
Photo of current wiring attached.
  • [ElectriciansForums.net] Honeywell st699 to st9400c wiring
The st9400c installation manual has a terminal by terminal replacement guide chart for swapping a 699 to a 9400c
It's available here if you don't have it in the box for some reason.
If an existing terminal has more than 1 wire all those wires must go in the new terminal (except the links in terminals 5 and 8 as they are internal in the 9400c)
The original wiring is all 'old' colours, including one of the blues, which is part of a red/blue/yellow cable.
There appears to have been a 'new' colour wire added at some time - a blue/brown flex, which may or may not be a bodge, so proceed with caution.
There's also no sign of any earth wires in your pic. Unless the wiring is really old, each of the cables should have one, and they must all be connected together..
Thanks, any terminal with more than 1 wire went into new terminals. Fitted and working. Thanks.
Reply to Honeywell st699 to st9400c wiring in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
