Honeywell wireless stat DT92E | on ElectriciansForums
Discuss Honeywell wireless stat DT92E in the Central Heating Systems area at ElectriciansForums.net
hi guys, customer has no thermostat for his heating so he brought a Honeywell dt92e. I am trying to install it but can't link it up with the programmer (2 channel Drayton) I have wired the stat up with a perminant live and it fires the boiler. But I can't get it to work properly with a programmer as well. there isnt a wiring diagram containing a programmer, any ideas.
Is there two x two port valves or 1 x three port valve?
2 two port, one for hot water one for heating
Okay the relay box needs permanent live and neutral to terminals L & N then CH ON from programmer connects to terminal A and brown from CH valve connects to terminal B.
If there is no thermostat originaly then CH ON from programmer and brown from CH valve will be connected together in the same terminal in the wiring centre. Just separate them and connect CH ON to A and brown from valve to B along with permanent live and neutral to terminal L & N.
Reply to Honeywell wireless stat DT92E in the Central Heating Systems area at ElectriciansForums.net
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
glad it was such a simple fix..... And good job the previous owners didnt take it with them
